Help on wiring multi-volt transformer | on ElectriciansForums
Discuss Help on wiring multi-volt transformer in the UK Electrical Forum area at ElectriciansForums.net
Trying to wire up an outdoor flood light, I have a 240 volt line in (two hot one ground)
any guidance on how to connect to terminal block?
  • [ElectriciansForums.net] Help on wiring multi-volt transformer
If codes permit, connect one 120V hot to the 240 terminal and the other hot to 0. The neutral is not needed. This will deliver 240V to the lamp circuit which will function, but will also result in the outer contact of the lamp socket being hot. I am not sure whether this is acceptable for safety reasons under the NEC.
Reply to Help on wiring multi-volt transformer in the UK Electrical Forum area at ElectriciansForums.net
I have a 13v AC transformer, to which wire numbers should I connect it to without destroying the windings. This was an old arc welder with a...
But if it's a looper shouldn't I have 2 hot wires just at the switches? Why two hot wires at the light? Sorry if it's a silly question
