Have been asked to wire up a hot tub. Have not done this before so after abit of help.
The tub is rated a 10kw using 45.5amps on the incoming cable to tub is a rcbo.
The tub is about 6 metres from the main board.
The plan was to run 10mm t&e in conduit on the outside of the house going to a isolator on the outside wall then feed the tub from this in swa to the rcbo.
Now with me running all the cable outside and also the fact the tub has a rcbo do i still need to put the cable from the board on a rcd.
Have I got it right or so badly wrong
