*Help please* Adding a light to an existing 2 way circuit | on ElectriciansForums
Discuss *Help please* Adding a light to an existing 2 way circuit in the Talk Electrician area at ElectriciansForums.net
D_Hurst
Hi - very new to this forum but having had a look at some of the previous posts - this is probably the best site for me to get some help.
I have a lighting circuit i my garage (1 light activated from 2 switches) and i need to add an additional light to this circuit. I think it is as simple as running a 1.5mm cable from the current light to the new one but am probably wrong.
If anyone can offer any advice it would be great - in terms of skill level, i don't thnk it's beyond my capability but i have been given a couple of estimates of ÂŁ100+ which does seem a little extreme !
well ÂŁ100 not that expensive especially if its a vapour proof flourescent fitting, labour traveling to site when you look at the costs involved its a reasonable price , it is simple 1.5 to next fitting joint cables to appropriate terminals and the jobs done , but if a spark was to do it then you would get a Minor works certificate
If it was near me I'd charge an hour and half for the first hour (ÂŁ39) plus bits. so a fiver for a batten light and a bit of 1.5. ÂŁ44. ÂŁ100+ is steep
Reply to *Help please* Adding a light to an existing 2 way circuit in the Talk Electrician area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
