Or 25mm oval ?I'd use 20 mm conduit myself
Discuss Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
20MM tube buried and plastered over, trying to get 2x2.5mm T and E in? good luck with that.I'd use 20 mm conduit myself
Or just install one conduit fir each cable.
Don't make it right though DDI have actually seen this done before on a few new builds
Shot run in a straight line not a problem perhaps your not gentle enough20MM tube buried and plastered over, trying to get 2x2.5mm T and E in? good luck with that.
"Gentle enough" please explain!Shot run in a straight line not a problem perhaps your not gentle enough
If you have two fit 2 X 2.5 t+e in say 1500mm of 20 mm conduit as long as the cables are straight then they will fit easily with no lube in sight"Gentle enough" please explain!
I agree if the tube is fitted to a wooden wall in a classroom. Lost count of the number of rewires I was involved in, where the buider has jumped the gun and stuck some conduit in and plastered over it, "sparky can get his wires up there no problem"If you have two fit 2 X 2.5 t+e in say 1500mm of 20 mm conduit as long as the cables are straight then they will fit easily with no lube in sight
How many dead straight runs have you come across in tube chased in and plastered over, only takes a little curve or deviation to spoil your day imo.Shot run in a straight line not a problem perhaps your not gentle enough
Reply to Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
