Help please - Is this acceptable? | Page 3 | on ElectriciansForums
Discuss Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
A bit bizarre handing out step by step instructions to a DIYer ..
No problem with this
In fact you could go one step further and run in the cables to the various points and take the legs back to the board
Ready for the sparks to connect up
Youll have the union reps on you for that one.
How will the "Sparks" be able to be sure the cabling has been installed correctly, and sign it off as satisfactory? this is a kitchen.
Pull it out, have a look and pop it back, if he's inclined to do so, I doubt he will be though.
If the job is small and as simple as the OP states then a cooperative, busy Spark would be only to happy to assist in making easier for all.
Some of the miserable old curmudgeons on here are a different story though.:p
If you have two fit 2 X 2.5 t+e in say 1500mm of 20 mm conduit as long as the cables are straight then they will fit easily with no lube in sight
Just done that on a job, 20mm conduit straight into boxes, builder dot n dabbed over, plastered, then I cabled ready for 2nd fix.
Good luck getting 25mm conduit into your backboxes.
Reply to Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
Many thanks. Very clear!
