Recently fitted a 3 x 4ft fluros - anti corrosive/IP rated, in a pub kitchen.
Didn't even think about heat dissipation - stupid me.
The one that is nearest to the cooking area has now become brittle and has come off its fixings.
So went back to the wholesaler and it's only rated up to 25 degrees, apparently this goes for most of the other decent makes like fitzgerald etc ? Is that right.
So what they've quoted me for is a fitting that is rated up to 55degrees, and apparently its explosion proof. It's a make called Hil Clare @ ÂŁ120+vat.
Bit of an expensive mistake on my behalf.
Anyone else had a problem like this before ?
And are there any other cheaper makes that are also rated up to a higher temp ?
Many Thanks,
Sy
Many Thanks,
Sy
