squashabe
[FONT=Verdana, Helvetica, Arial, sans-serif]Hello I'm new to the site and if possible can anyone please help, although I realize that it's not an electrical question. I have installed Cat 5 e cable to socket outlets in living and bedrooms. I have taken all the cables to one point where I plan to plug into a router which will be connected to a BT line. The BT lines comes into the hall and I have run a Cat 5 cable from the BT master socket to a point where the router will be located. My plan is to extend the BT connection from the master socket to a cupboard where the router will be. Can anyone please help with the wiring arrangements. I need to know what cables I will connect to the BT master socket to extend this. Currently it has only two wires connected a blue and orange wire. Secondly how do I connect the wires that will plug into the router and connect to a face plate where I can plug an ethernet cable to get internet access for laptops, or to connect a Playststion 3. Also, is it also possible to use the same socket outlet for a phone connection? [/FONT]
Thanks and I look forward to hearing from anyone who can help.
Adrian
Adrian
