Help please Sunnyboy SB1700 in constant waiting mode | on ElectriciansForums
Discuss Help please Sunnyboy SB1700 in constant waiting mode in the Green Lounge (Access Only) area at ElectriciansForums.net
Had a call from a customer we had installed their small array back in 2011. System is not generating and panels showing on a rainy Sunday 305v zero watts.
Green light flashing once per second in waiting mode even on a sunny day. Was a good day yesterday 24oc No fault codes/ messages or blink codes on the inverter. Measured voltage 243vac at the inverter, 24v neutral - earth, zero volts N-E at consumer unit.
Would this fault be more likely the array strings rather than the inverter
Reply to Help please Sunnyboy SB1700 in constant waiting mode in the Green Lounge (Access Only) area at ElectriciansForums.net
I unmounted the intrument cluster and the pins was fine also everything OK with it.
