I have recently had installed an 8 PV panel and inverter on to my roof. This was a local authority initiative which was installed free of charge. The system has been working and reductions in my electrical usage is being assessed. I was so impressed with the reductions that I have had a further 18 panels, another inverter and a storage battery installed. This also seems to be working satisfactorily and can be monitored through an App on my phone. What I can't get my head around is how the 2 systems work together? The App for the second (18 panel) installation shows that electricity is being generated during the day and either used internally to my house or into the battery or to the National grid. But what is happening with the electricity being generated by the first (8 panel) installation? The first (8 panel) installation is connected through a double pole isolator straight to the incoming tails of the main electrical meter and the second (18 panel) installation is wired into an MCB on the main consumer unit. Can someone explain if this is correct and I'm using all 24 panels worth of generated electricity in the most effective manner? Thanks
