R
remoulds
So I am trying to run power to my shed, problem I have is…….. We have an old type CU with the wire fuses, I already have a light outside but this is fed from a bedroom socket(Main Ring) with a bit of twin & earth 1mm sticking out of the wall and running down the side of the house(Outside) with no protection. Hardly 17th Ed, Probably not even 15th….
What would be my easiest way to get power to the shed? Is it possible to do this without changing the CU??
Thanks in Advance.
Thanks in Advance.
