J
Discuss Help Please in the Talk Electrician area at ElectriciansForums.net
The only thing i know is boiler fitted in outhouse and bond 10mm is run in to earth on sheath no bonding to water main other bond goes to head with pen condoctor from side to nuetral in fuse box
wouldn't a psc and pefc test on tncs be the same? if so you you've found your answer
Reply to Help Please in the Talk Electrician area at ElectriciansForums.net
