A
astropete
hi al,l newbee here and this is my first post.
now the question i am about to ask may sound dumb, but here goes
we all know that 2.5mm t/e cable is use for ring mains, but how do we prove that. a question on a course work i am doing requires a ring main circuit to be designed from stratch. this is how far i have got (now no laughing)
i have given 7200W as a maximum for the ring main
so Ib = P / U
= 31.3 Amps
In = 32 Amp RCD
It = In / CFs
It = 32 / 0.85 x 0.88 (thermal and grouping)
It = 32 / 0.748
It = 42 Amps
now 2.5mm takes 27Amps max when clipped direct, do i devide the calc by two
ie It = 42 / 2 = 21Amps (so the 2.5mm t/e can be used)
please help
the man (pete)
Ring circuits covered by 433.1.5. For a ring circuit each branch should have a current carrying capability of 20A, if the load current in any part of the circuit is unlikely to exceed for long periods the current-carrying capacity of the cable.
What you need to do is take the 27A for 2.5mm and apply the thermal and grouping effects to that, and I believe that will be greater than the required 20A.
Thats my 2p worth anyway!
help please
astropete,
yellowvanman,
