help please | on ElectriciansForums
Discuss help please in the UK Electrical Forum area at ElectriciansForums.net
N
nobelz66
could someone verify a cable size for a sub mains please
The new sub main is supplying 15 new log cabins each rated at 32A also taking into account of a (63A SUPPLY TO A SMALL DWELLING)taking diversity into account and volt drop and current rating of cable i have come up with a 120mm2 swa xlpe 4 core with a 95mm cps (UNDERGROUND)
the new supply run is 110mtr
many thanks
Reply to help please in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
