sivoodoo
Just been looking at a condition report from a property a friend is buying.
Its a TT system, Ze measured at 200 Ohms earth rod.
Ring final circuit 2.5mm, 30mA RCD, the measured Zs is 9.8 (max allowed is 1.44)
There is a 100ma main switch with operating time of 327ms.
The report says Satisfactory, is this the case???
max. Zs for a circuit protected by a 30mA RCD is 1667 where the RCD is used for fault protection.
R1+R2 = 0.32
r1=0.36 rn=0.39 r2=0.87
But yet the Zs = 9.8 Ohms??????
Ze can not be 200 Ohms, test it and find out the true readings.
Tel as already said it, RCD as an up front fault protection. I also think that the Ze on that test sheet has been made up. Bet the true Ze reading is 9.7 Ohms??????
that's what im thinking, in fact all other 8 circuits show a measured Zs of 9.8.
Age of the installation estimated at 35 years.
IR readings are +20 on all circuits.
I've not tested it. This is someone else's report.
Zs values brought down by gas/water bonding? if as you seem to say, all circuits are recorded as 9.8 ohms, then it's made up.
Do a "true" Ze test and take it from there. That 200 Ohms on the sheet is rubbish imho. Made up in the van whilst counting the money.
This is your friend so just go and do a few tests. Rip that EICR to bits.
Paul is right, that stupidly high Ra figure is just ripped from the OSG. Test it yourself.
yes ill try get access again and test. The place is ancient the cutout is antiquated, one socket per room etc. My friend is trying to get some money knocked off the price of the house. But this report says its satisfactory, what should i do if my test results are wildly different?
Explain the results and offer recommendations needed (if any), let him make the choice.
Test it to your ability with the qualifications you have to back you up and shove it in the face of anyone that questions your results. That works for me.
Look, at the end of the day testing is physics. We test the actual metal conductor and the insulation which it is protected by. Your testig it, you tell who ever the results and just tell them "This is physics" you cant change the laws of the universe ffs. Stick it to them if need be.
What I'd do is invite the person who carried out this EICR round for a chat. Ask him/her to explain the results and the contents of the report, all the while saying nothing about what you're doing for a living.
When he's finished and looking all smug and self satisfied then, and only then, pull out your test results and ask him to explain the anomilies.
I'm an intransigent old bar steward though.
If the vendor commissioned the EICR it’s bound to come back as satisfactory. That’s what they’ve paid for, they’re going loose out if the wiring is shot.
Your friend as the buyer should commission his own independent report if he wants to use it as a bargaining tool.
Why hasn’t he asked you to do it?
satisfactory because is ok compared to 1667ohms in the regs book? (for RCD protected install)
dodgy values because it was raining for last week and ground condition have changed? buried water/gas pipe bringing the value down when measuring Zs?
It's quite realistic to have a 200 ohm rod and a Zdb of 9 ohms.
Very common in TT systems near to PME installs. Normally gas bonding creates the parallel path. So the report could well be correct.
See it all the time in the depths of cornwall. Lol.
Tut tut, that would assume their were some real cowboys about 35/40 years ago too, before the common use of RCD protection...!! If this TT install is 35/40 years old, i'd be surprised if electricians of that era left an earth rod at a Ra of 200 ohms!!
It probably started out as a VOELCB as original provision,in my neck of the woods it's still fairly common to come across these still in use.Standard rod always seems to be a bit of galv conduit whacked in with a 2.5mm-ish wire back to the ELCB. I doubt very much whether any Ra measurements were taken.
Help please
Thread Tags
sivoodoo,
Deleted member 9648,
