help regarding long meter tails | on ElectriciansForums
Discuss help regarding long meter tails in the UK Electrical Forum area at ElectriciansForums.net
P
pablo4321
Hi just after a bit of advice,we are wiring a new build where the meter is, the tails will be coming from outside into the kitchen they will be coming up the wall to the ceiling along the the middle of the joists to the consumer unit in the wall what is the best way to do this
1) shall i run them in steel conduit and earth the conduit to the earth terminal in the meter.
2) do i need a overcurrent switch fuse in between
3) and is it acceptable to use just normal meter tails to run under the floor in the middle of the joist.
thanks for any advice.
No need for 2 threads to get the answer mate, Murdoch already on the case on other thread, answer his quostion and keep the thread going
Reply to help regarding long meter tails in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
