help required please | on ElectriciansForums
Discuss help required please in the Talk Electrician area at ElectriciansForums.net
shepped0
Hi All
New to the forum so please be gentle with me.
Firstly i am not an electrician however i am employing one to to do the job below.
The reason for my post is that i have used Electricians in the past and have spent more money rectifing problems down the line and just want to make sure the work proposed is correct for the job.
I would like to supply electric to a summerhouse at the bottom of my garden.
it will power 1 double and 2 single metal clad wall sockets and 2 outside wall lights.
30 metres of 2.5mm 3 core armour cable which will be buried in the garden.
The supply will come from the house from behind a wall socket which is protected by the main RCD of the house. This will then go to an outside weatherproof switched spur unit IP66 then to the inside of the sumerhouse to the double wall plug then to a metal clad switched spur then on to a single wall plug.
I am unsure how the wall lights can be wired from here but your thoughts and comments are much appreciated and of course the electrician will certify all work with a certificate.
Reply to help required please in the Talk Electrician area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
