C
carbonlace
Need help wiring the following:
110V AC split Phase motor 3 Wire 3/4 hp
wires:
neutral
2 directional legs
ground
Contactor Block:
Allen-Bardley
cat#100-k12*10 ser A
i have two identical blocks with jumpers.
there is a pre existing cat5/phone line running to key switch now. trying to avoid pulling new lines to key switch.
need 3 wires going to switch:
hot
2 directional's
This is what the "boss":boxing_smiley: said to do:
Hot wire - L5
DIR-A1
DIR-A1
NEUTRAL-A2
red to motor 13 on bottom block
blue to motor 13 on top block
switch hot - connect to L5 on the other block and put a jumper between them.
Put a jumper from A2 TO A2
No other jumpers are needed.
LMAO AND ROTF. Please help. Got this job in morining:clap:
thanks for the help.
wires:
neutral
2 directional legs
ground
Contactor Block:
Allen-Bardley
hot
2 directional's
Hot wire - L5
DIR-A1
DIR-A1
NEUTRAL-A2
