Help to identify a part | on ElectriciansForums
Discuss Help to identify a part in the Australia area at ElectriciansForums.net
C
Chris Roach
Hi all,
I'm desperately looking for a new connector and pins for a PCB I removed from my fridge. Only problem is I don't know what type of connector it is, or where to find one.
I'm not an electrician, just like to fix things. By the looks of it the female connector on the PCB is fine, but the pins and wires into the male were terribly corroded, and that's the part i'm looking for.
I will post some images so you can see what i'm after, and any help you can give will be much apreciated.
[ElectriciansForums.net] Help to identify a part
Tried that, Samsung (makers) couldn't find what I needed, these large companies are difficult to contact, and its very hard to find someone who knows what i'm talking about.
I had another idea though...
How about I keep the plugs, and replace pins... Can I find the metal pins that go in the male plug on say CPC or something. And what would I call them?
Reply to Help to identify a part in the Australia area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
If the connector follows conventional layout, the missing pin corresponds to the one marked below (sorry about wobbly finger!) The row of pins...
