Hello, as an amateur camper converter with limited electrical experience, I was wondering if some kind soul could help please?
I bought and fitted a 12v Maxxair Deluxe roof fan, which I temporarily fitted unfused and straight on to the leisure battery - it worked fine.
However, I then attempted to fuse the circuit with a 12v blade fuse box/holder which didn't end well.
I extended the wires from the fan with the same gauge wire, brought them back to the fuse box, connected the box to the leisure battery again using the same gauge wire (will upgrade this wire when I add more devices), and fitted a 10 amp fuse. I can't remember the exact order in which I did those which is probably important, but at some point the fuse blew, and the fan refused to work ever again, with neither a new fuse nor connected directly to the battery.
I've been very lucky to get a replacement fan sent out, but I can't afford to break this one! Can anyone suggest where I went wrong please? I've attached a picture of the fuse box below, minus
the fuse.
Any help would be massively appreciated. Thank you!
Jim
the fuse.
Jim
