Help wiring a mechanical timer | on ElectriciansForums
Discuss Help wiring a mechanical timer in the UK Electrical Forum area at ElectriciansForums.net
ampletoni
Oxford
Hi all!
I need help wiring my mechanical timer. I saw a similar thread but the cables are different.
Thread
My current installation:
[ElectriciansForums.net] Help wiring a mechanical timer
My new mechanical timer:
The schematic for both wiring:
(New at the top, current at the bottom)
I will really appreciate some guidance on the correct set up.
My guess is:
Blue from socket 1 to the new socket 1
Brown from socket 3 to the new socket 4
Green/Yellow from socket to none
Thanks a lot for your help in advance
  • [ElectriciansForums.net] Help wiring a mechanical timer
It is in the attic. I have access but I was hoping that it was just a matter of connecting the cables. It is something that I can do with the current layout? Do I need to run new cables?
[automerge]1572366796[/automerge]
Well it is a thermostat and it doesn't incorporate a neutral which your new timer needs to operate. Why don't you have access to the boiler.
Does all timers work with neutral? what do I need to look in the specifications to find one suitable for my current cables?
It doesn't work as a heating stat. It only has an on/off functionality. It is the only way that I have to put a timer as I don't have easy access to the boiler.
That is a thermostat, and yes it only has on off functionality because thats how a thermostat works.
You won't be able to directly replace it with the unit you have purchased as there is no neutral there.
You could fit a battery powered programmable thermostat there to overcome the issue as these don't require a neutral.
Well said, buzz.....and Westy ;)
Reply to Help wiring a mechanical timer in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
