Help Wiring Motor - Reversing Starter | on ElectriciansForums
Discuss Help Wiring Motor - Reversing Starter in the Talk Electrician area at ElectriciansForums.net
leeds
Hello Chaps
I have inherited a motor with no starter. I have therefore bought a new switch but i am struggling to connect up. I would be very grateful if any forum members could give me some advise should they be familiar with this setup? It is a single phase motor, and i am trying to add a DOL reversing starter.
[ElectriciansForums.net] Help Wiring Motor - Reversing Starter
^^^What he said!
The mains wiring in the starter will need to be altered as that is a 3 phase starter. Also you will need to check that the coil voltage is 230v.
I could be completely off track here but what makes you say its a 3 phase starter, are you talking about the old one or the new one?
On the box the starter came in it states "single or three phase" if that helps, it came pre-wired, except for the thermal overload which i added on.
Apologies for the attrocious drawing, there's a reason I usually use CAD or Visio....
If the motor is cap start with an internal centrifugal switch, from memory this is the scheme for the power switching side of things. I'd usually just use a separate manual motor starter for thermal overload protection but I'd even omit that if the motor has a built-in current operated manual reset button.
If I've got time later I'll look in the Klokner Moeller schematic reference book and see if there's a betterr circuit diagram.....or even better I'll upload the book into the resources section of the forum.
Just looking at the pic it looks like the link wiring from the bottom of the FC contactor going to the bottom of the overload is incorrect, this should go in between the contactor and the overload, but again this is for 3 phase.
For single phase the single phase current has to pass through all three elements of the overload or it will trip. Have to trick the overload into thinking it is seeing three phases, hence the rewiring.
Reply to Help Wiring Motor - Reversing Starter in the Talk Electrician area at ElectriciansForums.net
Hi All, I have recently purchased a motor soft starter from aliexpress for a 3 phase motor Before connecting load I measured the input and...
I believe that it is incorporated into the 5 days. But will double check. Thanks.
