Help wiring receiver | on ElectriciansForums
Discuss Help wiring receiver in the Central Heating Systems area at ElectriciansForums.net
West Yorkshire
Hi,
I have recently purchased a hive heating control. I currently have a Potterton boiler with a integrated 24h timer. The only other control over the heating is a thermostat in the hall. I need to disconnect the thermostat and connect the Hive receiver. Any help is much appreciated. Please see below wiring diagram for Boiler and Hive. I plane to use 5core from the boiler direct to the hive unit.
[ElectriciansForums.net] Help wiring receiver
Reply to Help wiring receiver in the Central Heating Systems area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
