Help wiring two baseboards in parallel with one T-Stat | on ElectriciansForums
Discuss Help wiring two baseboards in parallel with one T-Stat in the DIY Electrical Advice area at ElectriciansForums.net
canada
Hello guys,
I'm in Montreal, Canada.
First, I just want to install everything and then call an electrician to validate and connect to the breaker.
Two baseboards in parallel with one T-Stat
Can you folks tell me if my installation (see draw enclosed) is correct? I was told to do it that way but the breaker shuts down (I know I said I'd call an electrician, but was too much currious). The only thing I was not told is whether I leave the black and red baseboards wires twisted together on each ones, but I think this is my problem.
Thank you folks[ElectriciansForums.net] Help wiring two baseboards in parallel with one T-Stat
Reply to Help wiring two baseboards in parallel with one T-Stat in the DIY Electrical Advice area at ElectriciansForums.net
Thanks will give that a try in a little while Cheers Writing to say thank you very much for that advice, its worked! Really appreciate the help
Going to be very difficult to answer this can you not get in contact with the electrician who installed it.
