Help: Wiring up emergency lighting | Page 5 | on ElectriciansForums
Discuss Help: Wiring up emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Fife
Trying to wire up emergency lighting, for some reason, this doesn't turn on at all, even when power is isolated it does not come on, so ive added pictures to see if wiring and everything is correct, tested to ensure there was power coming in when CB was on, and that there was none when it was off, any help appreciated, thanks.
[ElectriciansForums.net] Help: Wiring up emergency lighting
I'm also confused, where's the neutral?
If the unit is not fitted I would run a flex from a plugtop, link out L&SL to see if the unit is working. As Vortigern has also suggested the battery could also be goosed which won't be helping.
Even if he gets it going it may not last a three hour test. As said I suggest connecting up the fitting with a piece of flex and plug top to 1. test fitting works and 2. if fully charged the battery can illuminate the fitting for three hours before it is installed.
If the unit has been un-powered for a while that battery will be ******!!!
If the fitting is suspect, take it down and wire it to a plug top as already suggested.
Doesn't need a link from L - LS for it to work as the unit should charge, then drop the power and the light will come on if its working.
Fitting L-LS link will simply illuminate the lamp same as a normal light.
Another point to mention, when refitted the supply to the lamp should be the lighting supply that is used in the area for the normal lighting where the E/Light is located.
If its wired to the CU this may not be the case.
Reply to Help: Wiring up emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
Thank you so much for your help with this light work perfect now thank you again much appreciated
