Help with 2 way switch | on ElectriciansForums
Discuss Help with 2 way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Liverpool
hi
Socket fell off the wall and can’t get the switches to work in parrell, one works perfect the other is then obsolete
Can someone help, have attached pictures
Red wire on its own not live with any switch on or off.
[ElectriciansForums.net] Help with 2 way switch
fraid you need an electrician to sort that mess out. it's not wired upcorrectly, but without being on site, it's guesswork.
Reply to Help with 2 way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ah yes my apologies, thank you much appreciated.
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
