Help with 2391 question .......VOLT DROP....... | on ElectriciansForums
Discuss Help with 2391 question .......VOLT DROP....... in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I
ICE
Hi Guys,
I have a past paper (March this year in fact) with a question I can not get my head round, am I mis reading it or am I just being thick, Here is the question exactly as it appears in the paper. If snyone can help me it would be much appreciated.
I know 3% 6.9V for lighting and 5% 11.5V for other circuits and that VD=Ib x (R1+Rn) x 1.2
If you can help can you please explain to me and also show all calcs, (model answer)
Cheers in Advance..
Determine, showing all calculations, the maximum permitted voltage drop on a low voltage (LV) installation supplied at 230V from the public supply network for a:
a) motor circuit
b)lighting circuit
c) socket outlet circuit
:confused::confused::confused:
hello chaps if ya dont mind me askin where does the 100 come frm in these calcs 230x5/ 100??? thnaks
hi iceman the 100 gives % the question is set to test that you know it is 3% lighting
and 5% everythingelse . they ask for all caculations to prove you are not just working
from memory.
so 230x your % value and devide by 100 gives you percetage
we all know its 6.9 lights 11.5 c&g want to know we can calculate and notr just work from
memory
Upvote 0
Reply to Help with 2391 question .......VOLT DROP....... in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
As you have actually measured the cold resistance (R1 + Rn = 0.15) then you have the voltage drop at the expected current (60A) so you can compute...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Electrical Courses
