Help with 3 phase pump wiring to sprinkler controller. | on ElectriciansForums
Discuss Help with 3 phase pump wiring to sprinkler controller. in the UK Electrical Forum area at ElectriciansForums.net
Arlington, WA
Question on wiring? Sprinkler controller to 3 phase Goulds water pump.
Sprinkler controller: "open sprinkler" uses 5vdc for master pump start circuit
Goulds irrigator GT153 480v
Eton contractor with 24Vdc control circuit and over load.
Relay for sprinkler controller master pump on/off control circuit.
I need help with wiring the sprinkler controller and start relay to the contractor/overload. I can't seem to find anything on line that addresses my exact situation. Most all the motor start wiring has start, stop, float switches ect. All very straight forward. What is the correct wiring for this application.? I included all the components and the Eaton wire diagrams. Thank you in advance
  • [ElectriciansForums.net] Help with 3 phase pump wiring to sprinkler controller.
Reply to Help with 3 phase pump wiring to sprinkler controller. in the UK Electrical Forum area at ElectriciansForums.net
Afternoon you lovely people My apprentice is doing his C&G NVQ Level 3 and he needs evidence of 1st & 2nd fixing control equipment/panels. His...
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
