help with a calc | on ElectriciansForums
Discuss help with a calc in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
The Ranger
Say I have a circuit that pulls 16A @ 24V how do i work out the ratio for the load at 230V?
If we are talking linear transformer ratios then,
Power in = power out (+ losses, although less than 8% in most cases)
so
Vp.Ip = Vs.Is
Transform to give:
Vp/Vs = Is/Ip
therefore
250/25 = 15/Ip
Ip = 15/(250 * 25)
= 15/10 = 1.5A
or
250/25 = 10
or a voltage turns ratio of 10:1
You now substitute your own numbers
I'll flesh it out if you like, the circuit uses POWER, P=IxV. So your 16A @ 24V is 384W. (P=16x24). The new voltage generates the same power, so 384=Ix230. I=384/230=1.67A
Reply to help with a calc in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sounds like one of those jobs to swerve and let it be someone else's problem
