Diagnosing a faulty ABS module. Manual say to remove ground cable from battery, disconnect abs harness, and probe for continuity between power pin 15/18 and ground. Multi meter shows 1.5K Ω and 7K Ω respectively. Is this an actual short?
Discuss Help with a possible short in the Auto Electrician Forum area at ElectriciansForums.net
Has your metre got a continuity function, whereby it fives an audible sound rather than a resistance reading?Diagnosing a faulty ABS module. Manual say to remove ground cable from battery, disconnect abs harness, and probe for continuity between power pin 15/18 and ground. Multi meter shows 1.5K Ω and 7K Ω respectively. Is this an actual short?
Reply to Help with a possible short in the Auto Electrician Forum area at ElectriciansForums.net
