W
Wilk
My shower has suddenly started running cold on its usual flow setting. The only way that I can get the water warm is to turn down the flow to a really low level which gives an awful shower.
I am an electrician but have never done any shower testing/repairs before so I would really appreciate any suggestions/help with tests and meter readings that I can perform to identify the fault.
I would really appreciate any help that you can give.
Thank you
low water pressure or a dying shower unit. poss. due to build up of calcium carbonate inside.
only to have another part fail next week. don't be a tight ar*e go for a new one,
Ha,
Only problem with a new one is getting one with the same pipe and cable entry points. I have only just finished tiling the bathroom and I dont want to do anymore - ever!!!!!
had same problem. bought a triton, same kw only to find cable entry was moved to other side. took a big hammer and 4 new tiles to fix.
T
thegrizzlyone
T
Help with a Shower fault please
Australia
Wilk,
telectrix,
