Help with alarm | Page 2 | on ElectriciansForums
Discuss Help with alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
He hasn't got a sparrow in the loft has he?
Sorry bad joke.
Though probably not that daft seeing as I've had a call out for a faulty alarm panel as it was "beeping", I got there and within 5 seconds told the old dear that it was her freezer on auto defrost.
Sorry bad joke.
fu
nnily enough, i had a similar thing. was called out to the alarm panel beeping, and it was her smoke detector on low battery.
hi there i have an accenta alarm fitted in to my home which version i dont no as it being in some years, as far as i knew the panel did not work, the other day when i had a power cut my alarm box went off , beacuse of this i had to take the wires out of the panel to try and stop the alarm that did not work then the power unit and battery out that did not work either then went to the alarm outside took the wires out then it stop, looking to buy a new panel and alarm box, but what i am asking can some one help me to give me which wire goes in to the panel and box please tia
The new panel and box will have a small booklet included marked "installation instructions" just connect new panel as the booklet tells you too
The new panel and box will have a small booklet included marked "installation instructions" just connect new panel as the booklet tells you too[/Q
hi there thanks for that, today looking at just to buy the panel, and the alarm box, will that have the instruction in, as the main box that in my loft is all wire connecting except for the battery and the power cable
Does anyone have an idea why the alarm keeps going off in the middle of the night. I replaced the bell box and it seems to be ok since but any idea why this would go faulty?
could be corrossion of the pc. tamper switch not making properly, a loose connection in the bell box. obviously, if the replacement box has cured the problem, the fault must have been in the old box.Q.E.D.
Reply to Help with alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
