help with alarms system | on ElectriciansForums
Discuss help with alarms system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
daiplayer
Hi all
i know this isnt in the alarms thread but i cant get access to it :-/
Im looking to install an additional remote keypad for a mate in his garage ( so he can set it from the house ) .
its a : accenta 8ep 396 optima compact g3 .
Now where can i find a panel that will go with it ? or will any work ?
i know this panel can have a remote panel as i have downloaded the manual, just cant seem to find a specific panel that is meant for this panel.
any help is much appd :)
I am sure the Accenta LED keypad will work but do not think I have tried it with that particular panel. Try one of the better Accenta suppliers and phone them, they should be able to tell you. I know on some of the Accenta series they had to be after a certain date to support a remote keypad.
Edit - Agghhh someone can type faster.
out of interest , what deos backwards compatible mean ? i mean if i mount it backwards you wont be able to push the buttons ......:laugh3::laugh3::laugh3::laugh3::laugh3:
Haha, yes, very true.
Backwards compatible means that the G4 (generation 4) parts and accessories will work with G3 (generation 3) panels. The panel your mate has got is generation 3 so you need either a generation 3 keypad (chances of you getting hold of an old G3 keypad are slim to none), or a generation 4 keypad that is backwards compatible.
i thought i was backwards compatible, but then i re-read my school report and the teacher had wrote backward, complete waste.
Reply to help with alarms system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
The previous bell box worked fine. I think it was just lacking the added security of anti tamper. Can this one be wired the same?
