help with an electrical installation certificate. | on ElectriciansForums
Discuss help with an electrical installation certificate. in the UK Electrical Forum area at ElectriciansForums.net
P
poolsharkuk
hi again guys,
I have 2 or 3 questions about the EIC.
Firstly, the “supply protectivedevice characteristics”,
its an old ceramic style rewireablefuse I cannot see any BS-EN numbers on, and I have no way of knowingthe rating, I rang the electricity company and they have no record ofit either, lol
what can I put in the box?
Secondly,
ive installed 2 new circuits (bothradials) on the original 12 way board, a double socket on one, and a13a spur on the other, at the moment nothing is plugged in the socketand nothing is connected to the spur, (there for future use) underthe section “particulars of installation referred to in thiscertificate” ....maximum demand load...! what do I put in there. DoI have to work out the maximum demand of EVERYTHING that is being fedfrom this DB even thou I didnt install it.
Lastly,
the socket and spur are in a hallway ofa commercial premisis do I still have to tick the main protectivebonding conductors and connection verified boxes, if not what can Iput down?
Thanks again guys I hope I havent askedto much of you,
1. it's a 3036 fuse and needs replacing. probably needs a new head. all you can enter on the cert. is what you can verify.2. max. demand... add all the MCB ratings an x 0.4.3. why can't you verify main protective conductors? get the size by looking and the Ze should confirm. and what about main bonding to be verified as well?
are you sure its a 3036 fuse its a 3phase supply the fuses are about 6" high and 2"wide ceramic / rewireable,
I wasn't referring to the main earth, that is 16mm I can verify, I mean the supplementary bonding ie the gas and water.
add all the mcb,s and x 0.4.3 ,... I don't understand.
I think 3036 refers to the fuse wire, not the style of the carrier, so that would've been my best guess, yes you should always check the bonding, (before work commences) and advise upgrading if necessary,
he said to calculate your maximum demand, add the total overcurrent ratings of the protective devices then multiply by 0.43.
they are semi-encosed fuses to BS3036.
no doubt the service head will be cast...how many fuses are in that head?..3 or 4?
Supplementary bonding?
Do you mean main bonding conductors?
Boydy
Reply to help with an electrical installation certificate. in the UK Electrical Forum area at ElectriciansForums.net
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
