A
allybally
Hi, im just about to buy my 1st tester, im umming and arring between the Fluke 1652 and the 1653, but im quite interested in the Meggers, Any advice about which one to sway to, Many Thanks
Discuss Help with buying 1st tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Well Im a Megger 1552 man, it tests continuity on contact which is a great help when your up a ladder not having to press a button unlike the 1653. The D-lock (No trip loop test) on the Flukes are better though I must admit
Sounds like a cut and paste from the Megger PR dept>In "No-trip" mode the Megger MFT electronics requires 3 wire L, N and E connections for power and reference so that the sophisticated method of noise cancellation that the Megger uses can resolve the impedance from the low level "No-trip" current pulses, even in an electrically noisy environment. It is because of this multiple current pulse and noise cancellation technique that the Megger gets unfair criticism from users of other MFTs (Fluke particularly) for it's apparently slow "No-trip" test, however, Megger users get the last laugh because they very rarely have their test inhibited by a noise error.
Reply to Help with buying 1st tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
