sjm
Hi guys, I would greatly appreciate your help if possible please.
The system in question is TNCS at the origin. It feeds 1 x consumer unit with MCB feeding an office in the house grounds using SWA cable.
The office consumer unit has an earth rod, Ze of 170 ohms so not connected to the TNCS system.
The office consumer unit feeds another small consumer unit using 10 mm T+E to feed 2 x wall heaters.
The question is how would you record this on an EIC?
Origin as the TNCS main supply, then use 2 lines of the results sheet to record the 2 x sub main circuits, or origin as the TT office supply and use the designated line for a consumer unit that is remote from the origin?
Thanks in advance.
Steve.
Thanks in advance.
Steve.
