Help with consumer unit and MCB's | on ElectriciansForums
Discuss Help with consumer unit and MCB's in the Australia area at ElectriciansForums.net
Hi, I am training to be an electrician and would just like some advice, when wiring up a consumer unit you always put the highest amp mcb nearest the main switch, what happens when you get 3 x 20 amp MCB's, 2 of which are type B and 1 type C, does that matter what order they go in.
Thanks in Advance
Alex
Reply to Help with consumer unit and MCB's in the Australia area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
