help with downlights | on ElectriciansForums
Discuss help with downlights in the Australia area at ElectriciansForums.net
M
-matt
basically ive been installing some downlights in the living room, a whole 14 of them.
now my problem is i want to dim them, so ideally i need a switch that is capable of 700W :eek:
and the most powerful dimmer i can find is only 500W.
so what would be my best option to do here? i never thought that about it until i was looking for a dimmer and most were only rated at 250W.
and i take it a 500W switch would probably burn out?
so what should i do?
cheers,
matt
cheers,
matt
Can't you put them on 2 separate circuits,just a thought:D
Reply to help with downlights in the Australia area at ElectriciansForums.net
Neutral and live
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
