Help with EICR code | on ElectriciansForums
Discuss Help with EICR code in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
tom79bmth
Just doing a EICR report
On the upstairs lighting circuit for some reason they have taken two 1mm t&e up both cables are fine for IR and r1 + r2 both on a the same 6 amp mcb
I cant see it 2 be dangerous does this need a code ?
then it's no problem. although unconventional, there's nothing wrong with it. just get the r1, r2, and rN ( end/end) resistances as well as your R1+R2 for the circuit.
Hold on just because 2 lighting circuits are on the same MCB does not mean they are wired in the form of a ring but of course you would know that because you checked between them right ? or you suspect its a ring which one then
what OT means is-- have you established that it's a ring by measuring end to end resistances o all 3 conductors.
Of course I have, I am not going to look at it say that's a ring it's got 2 cables in mcb.
Anyway thanks for help telectrix, I haven't given it a code, just made a note of it on EICR
Reply to Help with EICR code in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
