J
justanoob
hi im not too sure if anyone will be able to help but worth a try anyway i have been asked if its possible to auto opener/closer on a box top. Specs of box top is like 150 cm wide but in 2 halves so each side 75cm and need it to slide out so basically 2x 75cm squares sliding away from each other if that makes sense im thinkin like a heavy duty slide bearing or something and putting a small motor to it they also asking if it can be like on a 13amp plug and when turned on it slides out and turnes off slides in so no like controller is needed. Hope this makes sense im on mobile at moment so when i get back to office i will try to do a drawing and post that too. Hope someone can help on this thank you in advance
