Help with electrical connection | on ElectriciansForums
Discuss Help with electrical connection in the Australia area at ElectriciansForums.net
W
wnn670
Hey all, after a bit of help after no help from maplins, b&q etc.
I've just purchased 2 display cabinets that have a spotlight in each of them, however one of the plugs is missing that the wiring goes into, I've tried all the places I can think of and have looked all over the net but can not find anything. The connection is as in the picture a blade and a pin, i have only seen this once before on my la-z-boy sofa for the electric recliner.
What I need is either another plug which will do the same job as the one I already have or an adapter of some sorts to make 2 connections from the 1 currently available on the plug I have.
Please see pics below for picture of connector and plug I am talking about.
Any help would be greatly appreciated, even if it is the name of the connection! That would at least be a start.
ImageShack® - Online Photo and Video Hosting
Ok just to make sure: You have a 3 pin plug that goes from the box shown to the wall socket & then leads coming out of the box going to the lamps, on the end of 1 of the leads you have the pin plug yes ? if thats the case then what you show is a 2 pin DIN plug & they're available from Maplins, Radioshack etc or possibly your local TV repair shop.
I have the 3 pin plug, which has the in built transformer, out of that is the 2 din connection for the wire which comes from the light. Problem is I only have 1 transformer plug and 2 sets of wires to plug in, so ideally need another transformer plug which will take the 2 din connection, or a solution to join the wires together do they both can go into the 1 existing plug. Both lights will be on at the same time you see
you could buy a 230/12v transformer, as used for 12v downlghters. these are generally 60 watts , so 1 transformer would comfortably run your 2 lights. cut the plugs off the lights and connect direct to the transformer. or, use the 1 existing transformer and hard wire the other light into the above, they are only around a fiver, but you would have to either hard wire the primary side, or fit a plug.
an electrician could sort this for you at not a great cost.
Gawd, trying to find the exact configuration of socket will be a job that requires patience and Google. I've seen the plug before and I don't think it's a recognised or official DIN configuration. It's a low voltage DC plug and I've only ever seen them or the equivalent female socket moulded on cables.
I wouldn't try running two from one power supply, chances are the PSU is closely matched to its intended load. I would get an electrician or electronics wizard to fit a standard barrel plug and socket instead. Then the world is your oyster, they're pretty universal. Just be careful though, polarity might be critical.
[ElectriciansForums.net] Help with electrical connection
Ok If you want to wire two lights to the 1 socket on the transfromer you shoud be able to buy a splitter from Maplins, take the transformer with you & they should give you the right part.
Nothing specific. If you feel up to the task, the specs are on the picture you've posted. If you have a local RS Components trade counter pop in and ask for suitable replacements. You'll want a 12V AC output one, cable of supplying about 1Amp and the necessary plugs/connectors to supply both lights.
Reply to Help with electrical connection in the Australia area at ElectriciansForums.net
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
