G
gibbyisking
hi im doing a install and the outside walls are insulated with kingspan. There is 20mm gap between the kingspan and the plasterboard. Do i wire the install with conduit drops and metal boxes or is it ok to keep the cables in the 20mm gap. its just a ring main circuit.
Matthew
Matthew
