Help with light wiring. | on ElectriciansForums
Discuss Help with light wiring. in the UK Electrical Forum area at ElectriciansForums.net
Shropshire
Morning all.
A friend sent these pics of his garage lights and I’m trying to fathom out how they are wired.
Each end of the garage has a 2G light switch. 1 switch does the main lights the other switch does the light above his workshop section.
From what I can see there is a 3 core taking the feed to the other switch on the side with only one wire in Common, L1 & L2
It’s throwing me looking at the other side as I am trying to work out how it is all being switched.
[ElectriciansForums.net] Help with light wiring.
I think I have worked it out right from the pics. Just wanted some confirmation from this with more experience.
I hate light circuits. ??
simple arrangement L and S/L to 1 2way switch. 3 core to 2nd switch. repeated for other light. just the 2 lights have their feed in/out at different switches.
None of the conductors connected to the switches are or should be neutral as indicated by the brown sleeving in the first photo.
Basically the brown/blue to the switches is permanent live/switched live return. The brown/black/grey between are common and two strappers. No neutral at switches.
As I said. I hate light circuits. ?
Reply to Help with light wiring. in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Thanks again for your help, now solved đź‘Ť
