Help with main switch/RCD on CCU tripping | on ElectriciansForums
Discuss Help with main switch/RCD on CCU tripping in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
justjust1
Hi all,
I have just finished my level 2 City & Guilds 2330 Technical Certificate so am relatively new to electrical installations but loving every minute of it.
Before i start a new business or get a job in the electrical world and before i finished my Level 3 and test and inspection course i have been doing some electrical work at home in an extension we are building.
I have installed a separate CCU with an 80Amp Main switch/combined RCD(30ma) because there was not enough room on the current CCU. This CCU has 32Amp ring circuit, 6Amp Lighting circuit and a 50Amp Shower circuit.
Everything has been working fine i have tested all the circuits and they are all good, but the other day i plugged my circular saw in (brand new Makita) which i have been using in the past fine and the main switch/RCD tripped!!!!! this then happened every time i turned the saw on 3 or 4 times. So i left all switched off for around 2 hours had some lunch, came back and all worked fine and had done ever since!!!!
Can anyone explain whats going on and why this happened?
As i said, i am a newbie so please forgive any terminology i have got wrong!
JG
could be surge on saw start up. . i have a similar problem with a 3kva 110v tranny. even when not loaded, it occasionally trips the MCB/RCD when first plugged in.
Thanks, this puts my mind to rest, sounds like its not anything i have done wrong! The weird thing is that the 32Amp (ring circuit) MCB stays on but the mainswitch/RCD goes off!!
must be RCD trip then. damp saw, or earth leakage on saw. if it's only the saw that causes trips, i wouldn't worry.
Reply to Help with main switch/RCD on CCU tripping in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Build up of Earth leakage from multiple machines and the planner just tipped it over the edge?
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
