E
Elidor
Good afternoon all.
Have just acquired a new Fluke T140 voltage tester but am a bit conserned about how it’s working. First thing i noticed is that when the L2 (+) probe makes contact with either L, N or E there is a buzzer sound and the LED “Single Pole Phase Test” is illuminated. This LED and the associated buzzer continues to be present when both probes are used and the voltage reading is taken. Im not convinced it should be making this noise as i don’t recall the testers used in the college behaving in this way.
What is this “Single Pole Phase Test” exactly? The feature appears to be described in the manual as a means of identifying a conductor yet the last point in the manual states that its not appropriate to use this method and that a double pole voltage test is always required. Im confused why this feature is there if the device itself recommends it should not be used?
