R
robert0881
Hi all. Having moved into my house i wanted to put a nice hanging light fitting above the hall stairs. i removed the pendant thats there and tested the circuit L/N N/E L/E im not getting 240 across Live and Earth. getting 240 between L/N no probs.
Basicly i have a switch upstairs which is a plastic switch.
Earth is chock blocked upstairs at the pendant and at the switch. downstairs switch earth is also chock blocked.
I dont want to rip open the ceiling to run a new cable in as the decor is lovely.
Im under the understanding as there is no earth connected i can only use a plastic pendant or a double insulated light fitting unless i rewire that circuit?
Since the downstairs switch is very close to the fuse box can i borrow another earth to let me fit a chandelier above the stairs.
having checked the rest of the light circuits in the house there all fine. its just the upstair one that i dont get 240 between L/E
forgot to mention its an old house and i do belive in the past it was fairly common in older builds to leave out the earth in light circuits.
thanks guys..
thanks guys..
