Help with NVQ Question Please | on ElectriciansForums
Discuss Help with NVQ Question Please in the UK Electrical Forum area at ElectriciansForums.net
igouli
Suffolk
Hi, need some help with this question cant seem to find any info about it anywhere?
Q: What does BS7671 say about a good connection?
Many Thanks!
get your BYB out and look in definitions and the index. that is what the book is for...
definitions will describe a connection and if you look in the back for the relevant regs it will tell you what you need.
think of it as good practice for future exams and work as knowing where to check things will serve you well
The only book I have is an on-site guide...
134.1.4 Every electrical joint and connection shall be of proper construction as regards conductance, insulation, mechanical strength and protection.
526.1 Every connection between conductors or between a conductor and other equipment shall provide durable electrical continuity and adequate mechanical strength and protection.
Thank you!
Reply to Help with NVQ Question Please in the UK Electrical Forum area at ElectriciansForums.net
Isn't it just a little sad that it should cost sooooooo much to LOG a few jobs to BC.... O where did it all go very wrong ? Signed Man in tights...
Hi sparks, this has probably been asked on here before but I couldn't find an answer using the search function. About to start my 2346...
