C
Clyro
So I'm currently attempting to find a fault with a 5 ton indoor crane. Right the crane doesn't work at all but there is power all the way up to the panel which is mounted on the crane, I have opened up the controller which hangs down from the actual crane and I have no power going to the controller. Might it be the transformer that is faulty. Keep in mind this is a fairly dated crane. Any help will be greatly appreciated as this is my first post.
