I am looking for an waterproof surface box with a clear window in it to be able to mount a check meter into it so that it can be read from outside without having to remove the lid.I have seen something similar on caravan parks where the caravan hooks up to the supply but cannot seem to find any links.Do you guys know of any suppliers that might be able to do what I need?
Caravan hook ups are made by Rolex. Can buy direct or from usual wholesalers.
They may do one-off variations on their boxes, but it’s all standard stuff inside, could build your own.
Actually, I might have spare replacement clear panels for the fronts. I’ll have a look today
Ok, I don’t have a spare “window” but I do have a spare opening window that would be used to access the rcd/mcb in a hook up.
Sealed up in its little bag. Yours if you want it.
The sunlight through a clear window can knacker the display on meters, sometimes in months if facing south. I often put a rubber flap over the window to protect the screens, it can be lifted up to look at the meter.
Blackpool,Lancashire.
United Kingdom
Help with outdoor meter box?
Bob Geldoff1234,
ChipFanDave,
