Help with outside lighting.... | on ElectriciansForums
Discuss Help with outside lighting.... in the UK Electrical Forum area at ElectriciansForums.net
LewisM
Luton
Hi, I need help to find an outdoor wall/step light. It needs to be surface mount but not wider then 70mm as they're to be mounted on the posts. It's to light up some very dark stairs at night for an old lady who's just had a hand rail built after a fall. I can't seem to find any that aren't recessed.
[ElectriciansForums.net] Help with outside lighting....
Have a look at the Saxby Severus (61211) 3W LED brick light is 230 x 80. Mounted "the wrong way" it will only overhang the post 5mm on each side. They only project 27mm. I have used them for a similar situation.
Reply to Help with outside lighting.... in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Understood, ; ) i'll pass it on to a company who do them day in day out i think.
