L
LlandrilloSpark
Doing a PIR in a two bed flat, Im wondering what codes to give the following:
1. CCU is in the Kitchen mounted just above the skirting at 200mm height from FFL.
Cheers
Mike
1. None unless there is obvious signs that the CU could be damaged.
2. None unless the earthing system is TT or there happens to be a set of manufacturers instruction knocking about advising on different or that the fan should have it's own local fuse.
I would though recommend that a single gang switch is not the greatest way to provide isolation.
cheers Malcolm
As u replied i rang Napit helpline who said its a code 2.....FAIL for the ccu
prone to damage from hoover ect... because it is not in a cupboard and could then be tampered with by a crawling child, I said "what if it is in a cupboard",answer "still unacceptable...code 2...fail it"
Well certainly would have recommended that the client boxed it in if as you said it was open and not in a cupboard.
And with it being open then yes you could code it a 2 by the ESC guide referring to
[TABLE="width: 296"]
[TR]
[TD="align: left"]Unsatisfactory functional operation of
equipment where this may result in danger
[/TD]
[/TR]
[/TABLE]
So yes can see that and have no problems with that.
In this scenario,
CCU = Cooker Control Unit, as in for the electric cooker, or Consumer Control Unit as in "fusebox"?
That could make a difference.
Napit inspector told me to fail it on the grounds of potential damage, I told him it was pvc insulated, Ive just been to discuss/price moving it, its going to be a pig, I'm wondering if I could pass it if it were Metal clad? and lockable?
Or in a lockable cupboard?
At the end of the day, it is your opinion as to whether it's safe or not.
Id be happy to pass it if it were metal clad and lockable spin, yes its switchgear below 450mm but thats life
Morph get on the phone to Napit and shout at them, if you know anything at all about PIR codes then you will know its not all abot clear and present danger but also potential to cause danger, So there is a insulated CCU 200mm of the floor, I pass it, she hits it with the hoover and sucks up the bit that falls off, she doesnt notice or forgets, she sells the flat, kids move in, one pokes his finger in and he's dead, who inspected it last........??? answer Me..........judge "why didnt he spot the potential danger if was competent?2...
Did Napit say if a lockable cupboard made it ok? Sticking it a few feet further up the wall hardly makes it childproof.
he mentioned lockable pushrod , so my call is metal clad and lockable, id be happier then
so why is it a building reg. to fit light switches at 1200mm, within the reach of a child? should these then be metal and lockable too?
:behead:
no offense but the purpose of a pir is to state facts not what ifs or thats happen in the future
what happens if the child finds the key, or a hammer or screwdriver, could you not tell the customer to use a rubbery hoover :lol:
i'm just wondering how anybody could get a hoover to hit something 8" off the floor without throwing it.
Perhaps that devil of a child will disconnect the gas meter as well whilst he's dismantling the electrics
It seems people these days are getting influenced by the mindset of the worst of the H+S freaks
If its bashable there could be future problems with out of control Hoovers. other than that,if its in good nick,just make a comment on the potential bashability
Flooding would give more rise to concern for me, if it were that type of area
if my child strated messing with electrical equipment. first he'd have a sore arse, then he'd be enrolled on the 2330
if the hallway floods i would rather have an all insulated rather then metalclad incase i need something to hang on to !
so.... the conclusion is a fully insulated lockable, metalclad CU, rated IP68..... sorted.
lol
Now thats what I call wisdom and discipline all rolled into one
If got a board change on friday, it's located under the stairs next to the meter. I've never really thought about it, but would this not comply??
Door for under stairs is not locked.
and under the stairs, in the dark, is where we used to put naughty children!!!
My best friend for many years was a gas meter.
Then we moved to a flat and no longer had a cupboard under the stairs.
pass it move on!!!
"potentially" i might get hit by an aircraft engine next week falling from the sky so better tell the CAA to ban all flights just incase!!
pass it move on!!!
tghat's why H&S insist on hard hats in the open air. you might get hit on the head by a frozen turd from a 747.
Help with PIR codes for these items
LlandrilloSpark,
Deleted member 26818,
